Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Governor Removal ?
Posted by: CSimonGo
Is there anyway to remove the governor ?
And if so.. Are there any Pros & Cons to doing this other than speeding tickets ?
Posted by: MrWilson
i dont know, but for some reason, my car doesnt seem to have any governers, i have taken the needel off the 140 a fiew times...Pros: MUAHAHAHAHA! Cons: ....death, but then again there are only two things that are certian in life, death and taxes...and one is all about how you go out.
Posted by: 1wykdmk8
You can purchase a custom burnt chip to remove the govenor on your car. I am not sure if there is any other way but that to do it.
I had a chip in the AssassinVIIIor, and had it up to about 150ish, but had to back down because there was no straight road left.....so it is possible to have it moved from the 130ish that the factory set for it. If you have a chip burnt, you have to tell the person you are ordering it from that that is what you want, the govenor removed.....most will just simply move it up, not remove it all together.
