Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
2005 Mustang GT-R concept race car
Posted by: Joeychgo
Rice or Not? IMO the wing has to go...........
Posted by: Joeychgo
Here - without the wing.
Posted by: CaddyMaster
Ditch the wing, maybe add a more subtle wing -- and please change the color, its not time for halloween yet -
Posted by: MonsterMark
I'd like to see the second pic, (no wing for me please) with the car all in the same color as the hood. Would look very business like, IMHO.
Posted by: Joeychgo
MUSTANG GT-R CONCEPT TECHNICAL SPECIFICATIONS
Mustang Returns To Road-Racing, 5.0-Liter Roots With Mustang GT-R Concept
Mustang Racing History
Body
Lightweight RPS body panels with carbon fiber hood, aero devices, instrument panel, interior door panels and floor heal pads
Engine – Ford Racing 5.0L "Cammer" V8
Configuration
V-8, aluminum block, aluminum four-valve cylinder heads, forged aluminum pistons
Bore x Stroke
94 mm bore x 90.0 mm stroke
Displacement
5.0 liters (302 cu in/4995 cc)
Compression ratio
11.0:1
Horsepower
440 @ 7000 rpm
Torque
400 lb-ft @ 5500 rpm
Redline
7,000 rpm
Valvetrain
Double overhead camshafts, four valves per cylinder
Intake valves
Two per cylinder, 38 mm
Exhaust valves
Two per cylinder, 32 mm
Throttle body
Twin 57 mm
Drivetrain
Transmission
Ford Racing/Tremec T-56 6-speed
Rear axle
Winters/Ford 9-inch design
Gear ratios
1st
2nd
3rd
4th
5th
6th
Final drive
2.97
2.07
1.43
1.00
.80
.62
4.56:1
Differential
Winter's race-spec rear differential
Clutch
Ford Racing "Cobra R" heavy-duty clutch/flywheel assembly
Driveshaft
Metal matrix composite aluminum custom driveshaft
Exhaust
Complete stainless steel race exhaust with Tri-Y design headers, crossover and side exit tips
Chassis and Suspension
Chassis
Fully reinforced fabrication
Suspension
Original production geometry with lightweight chrome-moly tube (aircraft quality) construction
Front
Reverse-L independent rigid strut tower brace with lightweight chrome-moly K-member and race-spec anti-sway bar with 1.25-inch box section
Rear
Three-link, solid axle with dynamic, fully adjustable shocks with remote reservoirs and coil-over springs, race-spec 1.25-inch panhard rod, and race-spec anti-sway bar
Brakes
Front
Brembo Racing 6-piston calipers and 14.3-inch rotors, 1.25-inch thickness
Rear
Brembo Racing 4-piston calipers and 13-inch rotors, 1.25-inch thickness
Wheels & Tires
Front
Pirelli P275/35/20 racing slicks
20 x 10-inch, 5-spoke billet aluminum wheels
Rear
Pirelli P315/30/20 racing slicks
20 x 11-inch, 5-spoke billet aluminum wheels
Posted by: felo3769
and another one...came out in the auto show (forgot whihc one though)
Posted by: 1wykdmk8
I agree with everyone on the wing......I like the color....but not all of it....too much of it....but other than those things....that car is kinda hot!
Posted by: felo3769
yeah the side exhaust outlets are very hot!
Posted by: felo3769
now that i look at it closer...the exhaust outlets look photoshopped
Posted by: DreamworxsCustoms
Hi guys, just a few words, that wing will save your life in a 120 mph plus lane change or a nice sharp turn. The adjustable wing will also help tons on the track.
Posted by: Spidar6996
Quote:
All true
Posted by: 95Marklll(Kingcobra)
Why dont they call it a boss 302? Come on it has a 302, retro style, it would be perfect. GTR doesent cut it with me when i hear GTR i think of the 94/95 mustangs with the gt motor and base body. Call it a Boss 302.
http://www.fast-autos.net/ford/fordboss302.html
See how they resemble,lol
Posted by: daves2000ls
give it a different paint scheme and a shaker hood scoop and it would be a boss 302
Posted by: HyeLifeLS
Looks OK without the wing.
Quote:
Exactly, drop the import crap and throw a shaker on it. Another thing is there going to be any Mach 1 or bullit, I know about the shelby gt-500 but will there ever be a gt-350 or somethin. If only I had a hand in the system,lol
Posted by: Nakoa
thats hot, but it couldnt possibly take a mark 8. just ask lscgoddess.
Posted by: turborich
Yuck!
Posted by: Roadwarrior50
Quote:
I like it. And i agree, this is a Mustang that they did up for things like road racing, the wing isnt there just for show. Something like that will make a huge difference at the track. Its the same reason that the '00 Cobra R had a big wing on it.
