in my lightning that starts when the gas stations start with the winter blend fuel.|
Clamp the pos and neg together? You do realize some systems remain active for a while after the battery is disconnected, such as crash bags. I really would not recommend that.
As for Seafoam, it wont even get to the IAC unless you put it into the intake tube which can be VERY hazardous to the MAF sensor. Remember the IAC is on the throttle body. Typically one "injects" Seafoam after the TB directly into the intake manifold. |
. Worked for me (three times in five years of Mark ownership, two different models), and mine idles great.
. Maybe the IAC was not the problem on mine. but that's exactly like what was happening to mine-high idle all of a sudden, so much I had to stand on it at stops. I remember when it happened on my 93, stopping in a parking lot and looking to see if the throttle cable was hung up. I was later convinced that it was the IAC after going on this and other forums, and those fixes were found either here or some other forum, I'm just glad it worked. I occasionally still put a can of seafoam in the tank, and once or twice a year I will induce a half a can or more into the intake. If I have doubts, I'll do the battery cable thing, and have never experienced a problem. Because of where the throttle body is, I have no interest in pouring anything down there, I have only sprayed TB cleaner there, and that is only when I'm motivated enough to do so. I do not want to have to remove and replace the IAC, so I'm ahead so far (going on 6 years/about 70,000 miles total).
Jim Grant's Tech Tips (Alldata subscription service) Computer Dumping Q: I would like to know if you have any opinions on dumping the computer by taking the negative terminal off and touching it to the positive for 20 seconds to clear the computer of any stored codes. If so, will a vehicle that’s equipped with air bags, possibly deploy the air bag? A: Actually it’s a common practice to disconnect both battery terminals and not only hold them together but to connect them for the duration of the service being performed. For example when servicing the air bags some vehicles require the battery cables being joined for 15 minutes to a half hour before performing service or repairs that involve the air bag system. It is not uncommon for today’s vehicles to have several computers on-board. Inside the computers there are capacitors that will hold/store electrical energy. Connecting the battery cables provides a means of dissipating this stored energy without causing any harm. In most cases (not all vehicles) the software to operate the systems is not volatile and will be safely retained in the computer/s. If you have an anti-theft radio be sure you have the radio code so it can be reactivated. |
Jelsoft Enterprises Limited.
