| I have tried pumping the gas pedal during starting but it doesn't seem to make a difference at all. |
If they happen to figure this out, believe me I will post the results here. I am sure we aren't the only ones with this problem, there was someone else at the dealership this morning before me that had the same problem from what I understand. I am thinking that maybe there is a check valve in the fuel line somewhere that is not holding fuel in the line and basically starving the engine for fuel in the beginning or maybe the fuel pump is not being triggered to kick on when the key is turned for some reason. We will see what happens I guess, hopefully they can get this taken care of this time.
Just thought I would let everyone know where to start looking if they have this problem. Thanks everyone for all the advice also.
Problem solved finally, after weeks of going back and forth they finally found out what it was, a corroded wire in the fuse box in the truck. There was a leak on one of the seals that was leaking water into the spare tire compartment and apparently caused one of the wires to corrode. They found the wire, fixed the leak and I haven't had any problems now for more then 3 weeks. In all this I got a brand new battery, fuel pump, fuel pump relay, new wire harness in the dash and to drive a brand new MKX for 2 weeks
Just thought I would let everyone know where to start looking if they have this problem. Thanks everyone for all the advice also. |
vBulletin Copyright ©2000 - 2009,
Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009
