as long as the motor and tranny bolt right up, i mean still if it bolts up your gonna prolly have a truckload of codes your gonna go through...
ive thought alot about this, pedal set from a v6 5 sp, clutch and flywheel ( needs to bolt to crank dunno what would bolt up, obviously needs to fit under bell housing), new crossmember, and new drive shaft, hydro lines, slave cylinder... so yeah, get all that and the car will run and drive but the computer is the problem, |
vBulletin Copyright ©2000 - 2009,
Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009
