Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Help Heated/cooling seats stop working on Aviator
Posted by: juanchente2004
I have a 2004 Aviator and my battery went dead. For some reason when I installed the new one my heat/ac seats option won't work. It was perfect the day before. I took the manual and checked every possible fuse or relay and all is ok. That's the only option that didn't work after the battery swap. Looking in other forums and some people have the same issue but no one have a solution for it. I'm running out of warranty so I want to try to fix it myself because the fact of the stealers will kill you at the time to pay. Please any help on that will be really appreciated....
Posted by: freedom9ner
Strange, I've swapped out my battery and disconnected it a thousand times. Everything still works, including the ac seats. If it's under warranty they shoulden'd give you a hard time. Swapping batteries should not have killed the seats. If I think of anything I will re-post.
Home Loan:Myspace Layouts:Homeowner Loan:Personal Loans:www.fullbooks.net
