I own a 1988 mark 7, ive changed and fixed a tun of stuff, the whole cooling system, steering wheel, rack & pinion, rear control arm, etc... but now new problems have come up:
1) well one drunk night i decided to not drive and left my car in front of a bank. note:BANK (that apparently doesn't have any security cameras out front) . i come to get it the next morning the back right window was bashed out with a brick and my skateboard was stolen. anyway, i'm not sure how to install a new one, to me it seems like i have to take off the whole panel which i cant really figure out, and someone else told me i just have to remove the window trim which i also don't really want to try until i get a for sure answer. |
2) i keep getting a 31 code on the EEC tester, which is below minimum voltage to my EGR valve, i was wondering if anyone had the same problem, and if there is a quick fix, or do i have to get a new EGR valve.
3) for about a year now, the lights above the buttons for the fan, ac, etc.. flash, whenever they're on. anyone know what this is?
4) when i'm driving i hear nothing. but when for example, i'm at the drive thru, and i put my car in park, i hear a loud buzz/whine type noise, i usually just put it back into drive and hold the break when this happens. its coming from underneath.
5) Does anyone have or maybe has had a problem with the gas tank lying about how much gas it has. Someone told me its the floater, when its half full it tells me but below half randomly says 0, 23, 160, ive run out of gas probably 4 times int eh past 2 months because of this.
thanks |
Jelsoft Enterprises Limited.
