Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
measured oil amount
Posted by: Goddard-MarkVIII
Has anyone measured the exact amount of oil they put into there mark for the best performance results.
Posted by: 98LSC32V
I usually put in 6.5 quarts, which puts it right at the full line.
Posted by: unity
Use the dip stick, thats what it is for! You will not gain or lose performance based on a half quart of oil. Some say they take 6.5 quarts, some take no more than 6.
Posted by: chickenviii
i dance right around 6qts, mid of the stick.
on a side note my last change i tried 5w20 (ford recommends it now for gas millage gains, so they say) but i went to the drag strip a few days later, and i dropped a tenth. IM NOT SAYING IT WAS DEFIANTLY THE OIL but i haven't made any performance mods and i used to hit a 15.2, and with the 5w20 i hit 15.1's consistently. dont flame or bitch, im just saying it might be worth a shot
Posted by: 98LSC32V
The thinner the oil the less drag on the engine. I don't think it makes that much of a difference going from 5w-30 to 5w-20 but if you used a 10w-40 and go to 5w-20 the difference will definitely be noticeable. I have Amsoil 0w-20 in my 98 LSC right now.
Posted by: slowmkviii
are you woried about the amount of rotating mass or windage you should be able to get a crank scraper for around $80
i wasnt worried about it, just saying.
i tried 5w20 cuz its the same price as 5w30 at work, and when i went to the track, i beat my best time
and removing a oil pan on there arnt fun
5w20 is the same price as 5w30 at your work?
5w30 is almost double over here.
Posted by: Moes8
why is that?
Posted by: MYTURN
for all out racing the most horsepower would be so low that at the end of the quarter mile your pressure would go to zero than u shut it down.lol that could be 1.5-2.5 quarts.it would be worth 20plus horsepower of windage but may cause you to get the dumbass award of the year too.
Posted by: Markviiiedrea
I add 6.5 because my lincoln thinks its a Harley Davidson. It likes to mark it territory!
Posted by: turborich
I use my dipstick like the owners manual says to, To reach the full mark I use 6 3/4 quarts.
Well I figured different types of oil amounts would affect pressure. Not sure if this would change speed or horse power.
as far as 1/4 mile times you would have better luck taking the side mirrors off.
Posted by: Droplynx
Without going too far off topic, what do you guys think of 20w50 synthetic blend? Used it in my old 4banger and I swear it saved that engine from destruction...Just curious what you guys think though...
Posted by: 98LSC32V
I would not use anything heavier than Mobil 1 0w-40 in the 4.6 DOHC.
Quote:
That heavier weight oil would make a good cushion for a tired motor but then again the motor has to work hard to push through it especially when cold.
