Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
97 continental engine rotates but will not start help!! please
Posted by: DaReal
I got a new problem now when I go to start my car tha engine rotates but will not start ...now im geting fire battery is band new and tha altenator is fine now when its 70 or 80 degs outside it starts right up what could this be ???
Posted by: brentalan
You need to check if you have fuel pressure. It could be the fuel pump or some fuel system problem if you have spark. If you have anything rolling around in the trunk it might be simple like the fuel pump cutoff switch getting knocked to the off position.
Posted by: DaReal
nawh thats not it at all any other ideas
Posted by: MichiganTeddyBear
cam and crank position sensors.. known problems on 4.6's (at least in the town cars)
Posted by: DaReal
this is a V8 ...... where are theses sensors can they be tested
I am not familiar with the 4.6 v8's, other than what I have read.
but intermittant no start, stalling has been traced to a bad crank sensor. dont know if they can be tested, but if you can find it (I imagine its pretty tightly squeezed in there on the conti's), try to clean the connector first. if that helps, then I would replace it.
I am sure there are other people here that have more knowledge of the 4.6 than I that can help more. I am just going with what I have read, and common sense. The 4.6 in the conti and in the TC are very similar (nearly the same, main differences are for the FWD vs RWD, and different heads)
Posted by: bradyelich
If you search the forums here, you will find pictures posted of where the sensors are and discussions about them.
Regards,
Brad.
Posted by: DaReal
ok thanks
vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009 - Created by Stefan "Xenon" Kaeser
