Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Moonroof stripped
Posted by: Bud Badiali
New project. Anyone know how to remove and repair the moonroof if motor gear is stripped in the closed position.
Posted by: Frat-man-du
Is it stripped or did the bolts just fall out? Common issue especailly on Gen IIs.
Actually, I havent gotten into it yet. BEen workig on interior. But it sounds like gears running over each other like a bad door window motor.. Happens in either direction too, in either function tilt or slide. How do I start?
Posted by: OldSchool1
Quote:
Originally Posted by Bud Badiali View Post
How do I start?
This book is worth it's weight in gold.
very carefully pull the access cover off and take a look see. My Dad's 85 the motor had gotten loose and was just catching the gear. Same for my 98 Mark VIII - bolts had fallen all the way out and the motor fell down. Got all out of alignment - PITA to get aligned again.
Posted by: JoshMcMadMac
Quote:
A lot of VII's do not have an access cover for the moonroof motor.
Quote:
... and in these cases, then the vehicle owner has to ascertain the aftermarket manufacturer of the moonroof, and approach them for support.
Thanks for the feedback! My car has the access panel. OEM
Loans:Advertising:Loans:Mortgages:Remortgages
