Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
My Lincoln Mark VIII 97
Posted by: Goddard-MarkVIII
I just got my Lincoln officially today and it has a few little kinks to work out.
1. The passenger handle needs to be fixed. I'm guessing this is why the passenger door ajar warning comes up.
2. The interior lights aren't working. (Visor mirror lights, roof lights, dome light, glove box and storage box light) Probably a fuse haven't checked.
3. Check Engine Light is on. Does say it needs a oil change probably why.
4. And the last one the one I'm worried about most. When I idle it kinda sounds like the timing might be off and it gives a little knocking sound around where the front left hand side of the car.
I haven't changed any fluids haven't updated anything yet to get a better idea of where this thing sits, but I plan on doing that. I just wanted to know what you guys thought about it so far and how hard or how much its going to cost to run through all this stuff.
Oh yeah one last thing. Its a 97 Lincoln Mark VIII but for some reason I have a 96 Manuel is that normal?
5. Oh one last thing. For some reason my heat doesn't seem responsive. Just blows cold air.
Posted by: unity
1. Nope, the sensor is separate. Spray WD-40 in to the hinge latch on the door itself. If that does not work I can provide directions for removing and cleaning the sensor.
2. Yes, check fuses.
3. The need for an oil change will not trigger the CE light, get the codes pulled.
4. Describe the sound... I dont see what it would have to do with timing though.
Posted by: lscmkviii
Blend door accuator!
4. it kinda sounds like it was knocking its hard to explain it sounds like a pump. (pump, pump, pump) Is what it sounds like with like a half second delay on every pump.
? is that what its called I tried doing a search couldn't find it. http://www.car-part.com/
Posted by: unity
4. Its not a knock, more of a pump sound? Normally you hear injectors, but they tick.... I cant think what would cause a pumping sound other than the AIR pump, but I don't think it could even do that. Check out the high AMP fuses and try to disable the AIR emission system.
Checked every fuse it looked solid. Maybe a missing fuse?
Posted by: GMAN
Everything you've mentioned is typical fixes. The fuses would be the first to check. Do a search on all the threads by me and you will see all of the things I've done to my 97 when I first got it. Welcome to the ever changing world of Mark VIII ownership.
http://www.lincolnvscadillac.com/sho...hlight=no+heat Try this.
You have over 900 posts man.
5. Solved need the accuator.
Posted by: papa bear
4 more to go.. you are on your way to having a wicked car congrats.....enjoy
Posted by: chickenviii
yeah but doing the actuator sucks, i was able to sneak it out by only pulling half the dash, but it still wasnt fun
I found this hopefully it will help, but I wasn't able to find the temp fix lever anyone got a idea of where its at?
http://www.markviii.org/LOD2/blend_door_repair.htm
Download movies:Homeowner Loans:Share Dealing:Facebook proxy list:Mortgage Calculator
