We have a guy on here that says he has something coming but i cant see a rig like that doing much.
thats a whole lot of piping. What kind of numbers you get off of that. It's gotta be hard makin alot of boost in 12 foot of intake pipe. Hows the lag also compared to a charger? Are you gonna have a pipe comin out the bumper on one side and a intake filter on the other?
Dun, you should really research remote mounted turbo's a little bit more. It is ok if you want to believe that a remote mounted turbo will not "do much" on an LS. You will see numbers and I am sure your tone will change.
I like how there are always people who do not want to accept a new approach to making power in the performance automobile industry. For those of us who have been in the business a while we have seen this way of thinking before. Heck, even as little over 5 years ago people were still talking down on regular front mounted turbo's being able to make the kind of power to win races at the track or be suitable on the street. Those opinions have since been changed by hard results. The same will be said for the remote mounted turbo systems once enough people actually understand how they function, and how to correctly set them up. Until then we will still have disbelievers like you Dun. And honestly that is through no fault of your own. You are just a little misinformed; as allot of people are. That is fine with me, it makes things interesting. On another note, it will be nice to see other turbo LS's running around out there. It cannot do anything but slightly improve upon the vehicle's image. |
A turbo moves so much air that making boost in a slightly longer section of pipe like in the remote mounts will be easy.
A remote turbo is sized differently than a front mounted one. Once that is taken into consideration then spool time (lag) is greatly decreased. It is even easily possible to have a remote turbo spool too quickly if sized incorrectly. The name of the game is to have an even balance between maximum power and the kind of spool that you prefer. In short the turbo will spool to full boost quicker than a comparably sized centrifugal s/c. |
Here we go with the attitude right off the bat. I never said anything bad about it, I would actually like to know about it thats why I asked these questions. And I also asked numerous questions to you about your kit and you never said anything like this while I was paying attention to it, after we got no where I just fell off the topic, and please lets not go there again. I cant see it doing anything but it does so I am wrong which is why I want to know!
Misinformed? I was never informed THATS WHY IT WAS JUST SIMPLE QUESTIONS or basic conversation! Don't be such a dick about everything dude, I wasn't being cocky or anything at all! You got some real touchy nerves man. Why is it that you just completely ignored post #7? I think I know why. To just be a dick. |
It just seems like if you stomp on the gas it would create a dramatic drop in pressure it all that tube which would take longer to get the boost back up. But your saying the blades have a modified angle for a rear mount turbo to make up for this.
Dun, I did not post here in order to get on your case. I actually posted here to clear a few misconceptions up. In fact, truth be told I was trying to somewhat go to bat for you as one of those under-informed people making it clearly understood that it usually is not your fault for having the wrong info. Regardless of my intent you always seem to take it the wrong way so I give up with you. Have a nice day.
Cool, I appreciate the whole value in its entirety but its just not the same as a straight forward kit.
I do wish we had more room and understand that is the reasoning, I hope this works well cause this in consumption with the other kit makes even more areas of R&D to be influenced. Does the exhaust plumbing make up for what the extensive intake plumbing constricts? I mean, it seams like there is alot of intake for forced induction with a kit like that considering it is forced induction. keep us posted! |
| Maybe I should consider 04sctls's links. |
There is some work to be done to make this work in an LS.
You would probably have to combine the dual exhaust pipes into 1 to feed the turbo then split it back after it's been used unless you can live with a single exhaust and a dummy pipe in the back. This would be the most fabrication but not beyond the capabilities of a compitent exhaust shop. |
Would a twin turbo system work in this application (one for each exhaust line)? or would that be a case of deminishing returns for the expence involved?
forgive the ignorant question I am not intimately familiar with turbos |
I think one of the major obstacles in using this system in an LS, would be all the plumbing involved. There is not much room to work with under an LS and using a twin turbo setup would double the tubing. Not to mention the oil lines and everything else that goes with those turbos.
I've seen the STS turbo system in person in a Corvette and a Camaro. They both took up a lot of space under and in back of the car. The main thing that always worried me was the air filter down under the back of the car. I wouldn't want to drive through any deep water puddles or in the rain and forget about having your LS lowered. But the system does work and anything is possible with enough time, money and effort. |
Cool!
.....And speaking of cool..... How close together can the hot exhaust and and cool intake pipes be under the car? Are there any heat transfer problems with having the pipes too close together? Or would that be negligible? |
its up in the air between 2 shops i cant find the website for one of them but they are both very reputable one has a custom fabed awd sentra http://www.sstracing.com/sublimeweb/custfab.htm the other shop is C & S motorsports but i cant find there site. i dont want to lie but i dont relly know the cost of much of it i will look into costs of things when the time comes but i want to spend under 8k but they get it all winter i want it to be reliable as i will daily drive it as long as its tuneable to 92 octane.
If they need all winter to do this project then take it somewhere else. From start to finish this project, even if encountering hickups, should not take longer than 3-4 weeks of total shop time to do.
They should be able to do it for less than $8k. I have provided price estimates for my customers for less with everything out the door for a custom LS turbo system fully tuned with all the proper fuel system components and so on. A similar setup but in front mount would break the budget; another benefit of remote mounting. |
Have you posted an estimate of total cost. I see you say less than 8k, but can you give us a better idea. Also, how is your other post/project coming along?
So the idea of a rear mounted turbo sounds great. The idea that just the length of tubing the air has to pass through may cool it down enough is even greater. I'd hate to see a large intercooler defacing my lower grill.
The combined cooling of the longer path the air has to travel and a small, easily hidden intercooler would be perfect for our LSs, wouldnt it? In addition to the usual upgrades, CAI, catback, tune, would a rear mounted turbo with a small intercooler on less than 5 pounds of boost be OK for a daily driver? I mean I'd want to keep a low amount of boost on it 'cause I wouldn't really be looking for a huge huge gain in HP. With the usual mods and a rear mounted turbo I'd want to hit around 325rwhp and not put too much stress on the engine. I've got to drive it to work everyday and I'd like a sleeper daily driver not a dedicated racer. Think one could hit around 325rwhp with just an intake and rear mounted turbo with not too much boost? |
ILLS, I'm gettin' more and more jealous of your ride the more I read about these.
I'm a thinkin' I need a turbo Lincoln.
If you were to go with a remote turbo you would not use your regular CAI or catback exhaust as all new stuff would be made. It would not be worth it to spend money on those two mods only to do a remote turbo later on which would require you to either take them off or hack them all to heck.
You could easily hit 325 rwhp with a system like you described. If running less than 5 psi I do not see the problem with using it as a DD as long as it is tuned well and the bands in the trans are kept well adjusted. |
ILLS, we need to chat some time. As I was reading back through this you were in my head bro! Right on. Except I would hpe to see more than 325 but you did say easily. If tuned right I'd HOPE to see 350 to the wheels
People don't seem to understand how significant of a jump 300+ rwhp is for a pre vvt LS. I'm guessing that with parasitic losses, my '00 is prolly puttin' down about 210hp at the wheels, as opposed to the 250hp factory (crank)spec. When ILLS says he'll be trying to dial in 360RWHP that's about a 50% gain over stock (pre 04?) and still a SIGNIFICANT gain on a 04+. Hopefully this will happen safely with stock engine components, and around 6# of boost? Sounds pretty damn impressive to me. Since seeing some of these setups, I've been researching cost, availability, and simply put, what it would take to do this myself (if I even can). I read about a guy using an eaton off a t-bird and installing it on a v-6 (mitsu) dodge daytona. Not real pretty, but it works. There's a speed shop in Sioux City that put together a 1000HP SC mustang. The guy wasn't happy with that so he pulled the sc and installed twin turbos. Dynod at 1500Hp. The guy still wasnt happy with that, and they're dialing it in for 2K hp(5.4L Triton). This ain't gonna happen with a 3.9 v-8, unless you have a bottomless bank account, and perhaps not even for Daddy Warbucks. Being able to safely boost your engine 50% above stock, when the engine's CR is already high enough to readily burn alchohol, is quite an accomplishment. Cheers to QuickLS and ILLS for havin' the cojones to unleash the potential of these stylin' sedans. The numbers just seem to be getting bigger and bigger.
Yup that was me, and Ills I can't wait to make this happen. The wife is getting better day by day, just some more small hurdles and me and you are in business bro......
It all depends on the amount of boost you were running and the tune. I plan to hit around 360rwhp with my system once I pull it out of winter storage and change the wastegate spring out. The person whom I was talking to in your quoted post was looking for something a little more eased down.
Im looking at some custom made rods and pistons for more boost. If I can make it happen, I'll let you know. I wont boost if I cant get 8-12PSI from it, but if I can these rods and pistons, we might be in biz! I'll ask the guy about a possible group buy so the cost drops some. If you know any one or if anyone reading this wants in, let me know. This is still in the very early stages, but more than 5PSI would be a blast to drive!
I dont have a number in mind. 400 has always been my magic number. Something about Black Sunshine. If we can solve the compression ratio issue and get closer to 10PSI we should be able to blow 400 away. I'm starting out behind you and Quick do to my 1st gen, but thats no excuse. I should be able to hit the same numbers and same times. I'm curious about some other parts of the bottom end. Head studs, sleeves, valve train etc. If we change the comp ratio with some custom forged rods and pistons, will everything else hold up to the added pressure? Valve train probably wont be an issue unless cam work is done, but every chain has a week link.
I know they're not the weak point for breaking more so for robbing power in a forced induction. I havent messed around with the 4 valve system yet, so you got me there. Im sure your valves and cam are ok, but if mine were that great, yours wouldnt be different than mine. I appreciate the info. Nice to talk to someone like minded. Though is sounds like you have WAY more experience. And I'm always talking WHP. crank means nothing to me.
ILLS, NHLSV8...
Have you considered looking for off the shelf rods which would match up close enough that a good machinist could make them work? Really, as long as length is pretty close and the big end is a hair on the small side... what with offset grinds and the like, it might be totally do-able. Small end wouldn't matter that much if you're having custom pistons cut; just run whatever floating wrist pin the rods would take. And while I'm thinking about it, stands a chance you could absorb a couple thousandths +/- of rod length by adjusting wrist-pin location in the piston. Obviously you'd be very limited on your adjustments here, but I doubt you're 100% locked in. Just seems like you might have an easier time as far as your bank account is concerned if you could just rework and existing rod. |
Naaaah, the 4v heads in these cars flow quite a bit in stock form. It is hard to find a modern 4v heads that doesn't. If you plan to only shoot for 400rwhp then the cams will not pose an issue either. Also, flow becomes less important with FI when compared to N/A; though still important when going for truly big power. Assuming the shortblock could handle the power I would bet these heads (even yours) would EASILY support 600rwhp with forced induction.
I have considered that before. My approach is that if I am going to bother taking the time to build the 3.9 bottom end with something custom I might as well go balls to the wall with the rods, pistons and especially the crank.
Something I hadn't thought about before with putting twice the power to the ground is the tranny. We're tlaking heads, rods, pistons etc. but these tranny's are thought but many to be slushboxes. Something would definately need to be done to make this a "safe" application.
But if its going to be rearmounted with PLENTY of room, why not go to a dual inline. Get a smaller one for the low end and a bigger one to really push the air through!
I never read your posts and think t myself "what is he talking about!" I've said it before and now I'm saying it again. It's nice to come one here and have someone with your level of expertise AND who is like mided with me. I'm talking to the machine shop today about those rods and pistons. I'll keep you posted. I might just for giggles ask about an intake mani. Any thoughts about that? Sounds like these 4V motors dont really need much to boost and then rip up the pavement
Jelsoft Enterprises Limited.
