There needs to be a limited production number pre-set before production or there needs to be a limited run of special hardware/powertrain options.
The Diamond Anniversary were not a "limited production", it was a trim package option as far as I know. And as far as I know, these generally do not qualify. There needs to be a limited production number pre-set before production or there needs to be a limited run of special hardware/powertrain options. Generally this means that each will have a designated number, similar to the 98 Collectors Edition.
http://www.mark8.org/lod/Diamond.htm |
No, it was a limited edition, 75 years of lincoln
check the sig |
Does your 96 have the Diamond aniversary trim? If not then it's not a "real" diamond aniversary. I belive that all 96's are listed as diamond aniversary just as many catologs and insurance companies will have the 93-95 listed as LSC. I'm pretty sure that the diamond package has burgandy trim in the middle of the upper seats, a diamond on the rear side windows & a plaque with a diamond on it that came with the car.
Lets not turn this into a strut thing... but...
Limited means there is a limit on how many were produced. If I buy a limited print painting, I will own, for example, #325 out of 500. Another analogy is a speed limit. A limit is a pre-defined figure. "Production was limited to....." Special means extra options, packages etc that are or can be added but there is no pre-set LIMIT on the number of these packages. This is like the collectors edition of the 98. Ford did not say "we are producing only 300", they produced as many as could be sold. "Its believed only XXX were made...." Now a 96 with the DA package would NOT be limited, but instead "rare" so it should still be able to get the insurance if the milage is low, etc... If I have to make it any clearer I will have to teach some basic english! |
That last sentence was uncalled for clown
DA's were only on the MK8, Conti, and town car, other packages were offered/made in this year obviously, and that means they are limited. For all you know, there was 1,500 Mark VIII diamond anniversaries made, 40,000 town cars, and 3,000,000 contis And another way of saying it would be... "It [Mark VIII] was limited to XXX total [Due to none other be purchased]" Meaning it is limited edition [Diamond Anniversary Edition] And your "analogy" wasn't an analogy at all... O and by the way, edition is another way of saying version..... |
i have your info. due to your attitude i wont post it. |
Here ya go:
http://www.markviii.org/LOD2/production.htm Yes I am linking to Markviii.org, I will be taking a shower shortly... yuk. |
I dont think there is a number out there for that. If I had to guess based on what I have seen out there, less than 20%. I cant find an LSC build number and I am not sure it exists.
Jelsoft Enterprises Limited.
