He obviously wasnt stock though....
yes, those are the O2's. get them changed out and all should be well.
The O/E ones are a F5MZ-9F472-AA and list for 97.78 and LVC cost is $57.20 each plus ups.
Max |
no... not yet. i was tackling a very bad viberation at high speed issue for awhile. turned out to be bad rear drivers side hub and barring.
I may do the brake check valve this weekend or so... but i highly doubt it is going to be it. but, who knows...lol thanks for checking up on that w/ me! |
Before you go and change O2 sensors, go around the engine and check everywhere for vacuum leaks. If you have a vacuum leak that is out of the ocmputers tolerance, it will also give you those codes.
Jelsoft Enterprises Limited.
