This is a common problem with quadrajet carbs. Usually this is a combination of weak accelerator pump and weak secondary air valve spring. You may be able to fix it by tightening up the spring but eventually the accelerator pump should be changed.Quadrajets also had a problem with the power valve getting stuck because if the car backfires is can send soot up into the power valve. It's relatively easy to tighten up the spring so that is where I would start.A quadrajet is made up of 3 main pieces. The air horn which is the top piece, The floatbowl or main body which is the middle piece,and the throttle plate which is the bottom piece.These pieces are separated by gaskets so it is easy to see which part is which when you look at the carb.To tighten the spring: look on the airhorn at the passenger side near the back. You will see 2 large roundish plates on top of the carb.These are the secondary air valves. There is a piece of linkage hooked to the passenger side of these valves. There is also a small flush mounted straight screwdriver slot next to the air valve shaft.That is what you turn to tighten up the spring. You will also see an allen head screw going upwards into the air horn which locks the adjuster slot. Loosen the allen head screw and then turn the slotted one 1/4 turn clockwise then test the car for hesitation.If it helped but not completely solved the problem then try another 1/4 turn. If that doesn't work you will have to rebuild the carb. Make sure that the secondary air valves rotate freely and if they don't,spray the shaft with carb cleaner and work the valves open and closed until they are free.In addition, the piece of linkage that hooks to the secondary air valve shaft hooks to a vacuum can at the other end.If the linkage is mis-adjusted or if the can leaks vacuum that could cause your hesitation. Quadrajets are not bad,just picky .
Jelsoft Enterprises Limited.
