Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Rear Air Bags? Check Air Ride System :(
Posted by: mespock
Ok, this had been a bad month already.
First my Mark VII springs a leak in the front bags.
Today my Mark VIII has a problem with its rear air bags.
When my wife went to the car tonight I noticed that the rear end seemed to be a little high.
Then she can back into the house and anounce gues what, the car says check the air ride system.
I've been searching but haven't found any threads.
#1 What should I do to lower the rear air bags?
And
#2 what might be wrong?
Posted by: viiiball
sounds lke stuck solenoid....i just said the heck with it and replaced with coilover springs.
Posted by: ND4SPDLSC
Don't be so quick to convert. 99.8% of the time, it is an easy DIY fix. Check out my post on LOl.
Posted by: mespock
Quote:
I'm on LOL but can't find your post unless you are Nick -
If it doesn't lower, it can be a problem venting with the air spring solenoids (seems unlikely if both are up high), rear height sensors, or perhaps the vent valve on the compressor. The vent valve may have built up corrosion preventing free movement and is thus keeping the rear from venting properly. I don't remember where to find the self test for the VIII, but you should run it and it will help you narrow down your possible faults. I do know that the problem shouldn't take more than a day to find and to correct.
I've been searching for Viper8Ltr
Posted by: viiiball
i agree only replace if 2 or more bags are down and compressor shot....like mine thats why springs.......1 or 2 bags replace withe air from eddie
