Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Gas tank strap broke - can I fix myself?
Posted by: Kevin
Yep, driving home from work, over a bumpy intersection it broke.
Tank was almost empty so that helped me out.
It was the right side one, and I found out there was another one holding it on so I cautiously drove home anyways with the thing hanging down (hey, it was well after any/all repair shops had closed).
Is this a part I can repair on my own, has anybody done this? I'm worried about the body area being rotten where the straps bolt in, although the strap itself broke in the middle section - rotted clean through.
Posted by: Roadboss
I know Advance can overnite straps, so I would get down there, as it will require a deposit. I did not check the web site. You may want to call first. I used to work there is how I know,
Posted by: Markviiiedrea
If I would have known a few weeks ago, I would have given you one of mine, I'm sure some body out there is parting one out that you can get one from.
Posted by: mespock
I have one but not sure how fast I'll be able to get to it this week. Got things going all week. Might be able on the weend.
Price is Free... just pay the shipping Send me a PM...
Posted by: Kevin
Thanks for the offers guys, it's not the price that concerns me, how much can it be right?
I'm more concerned with whether I can do this job myself or not, I don't really want to pay $80/hour to get a new one put on....
I'll crawl under and take a look.
Posted by: Staffamerica74
Do it yourself why would you have someone else do it?
its two bolts under the car, I can asure you that you can do it your self.
Posted by: Frat-man-du
Pretty simple- Just wear goggles!
I have not my Mark, but have dropped tanks in the past, not a big deal, the more gas the harder it is - just remember an empty tank, although light in weight it is more dangerous than a full one due to flammable vapors.
Posted by: Kevin
Just picked up a set of straps for $31 at my local parts store - get under the car to unbolt the remains of the last one and knew right away that something was wrong -
They sent me the wrong straps . They only have a listing for a metal tank in a 94 Mark 8 - I thought they were ALL plastic? Mine is.
Yep, it's easy to do the work, but you have to have the right parts!
Posted by: Kevin
n/m
Posted by: mespock
Most important thing is to have a little gas in the tank as possible. Makes it a bit easier.
It's an easy job.. even at 15 degrees in the dark and on jack stands. With support.
Posted by: Kevin
MeSpock - I may take you up on your generous offer, and I'll add $20 for your trouble, it's worth at least that.
I have sourced some flat bar 1"x1/16" in galvanized, and may rig that up, but I don't like that because I'll never get it 'perfect' and tight enough without jambing stuff in between the tank and strap.
NONE of the car parts stores in my area can get me a strap, not even Ford - it's 'obselete'. Supposedly 97/98 won't work, are they really a different tank? They can't get them either though anyways.
Posted by: JMiles_T
I don't know for sure, but the Thunderbird/Cougar part might be compatible.
Blog5 Game Cheats:Comprar vivienda Denia:Loans:Photoshop Tutorials:Savings Accounts
