Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
300 shot buildup for my 97 mark
Posted by: krose311
I know I need crank,rods, and pistons probably go with je n20 pistons. I have 3:73 w/ trac-loc bbk adj fuel reg.,bbk highpressure fuel pump, lms 90mm mass air ,and nx 150 shot right now. going to go with j-mod 3000-3500 stall? w/ 4:30 gear. what throttle body is suggested and do I need cams? any advice would be greatly appreciated!!!! I run 13.8 @ 104 with a long shift where I have to let off juice when It shifts (sucks) My goal is to be in 11's or low low 12's What is the best combo???
Posted by: 98LSC32V
You need to get your current setup running right first. 13.8 is very slow for your mods.
Posted by: krose311
the shifting problem is my problem. It,s bad I figure with flash tuner I can boost line pressure and that should make it shift better. don,t you think? I haven't installed fuel pump yet, and I got lean codes Intermittenly. What times do think I should be pulling? The 300 shot is not for a little bit I just want to know what the best set-up is so I can start buying parts and I can can get some good answers from you guys(gurus) ou really think I should be getting alot better times or what I,m only spraying 100 shot at the time of 13.8 didn't want to push it with lean codes. How do you get to shift at 6800 and not 6200? If I manually shift I have to shift at 4800 to get it to actually shift at 6200. to scared to do that on spray dont want to hit rev limiter!
Posted by: JoeyLincolnMK8
by doing the JMOD or adding a shift kit, you will increase line pressure to the trans anyway. no need for a flash tuner to do this, but adding a chip is still good too. also, slap on a trans cooler just to play it safe! good luck.
Posted by: driller
Quote:
Originally Posted by 98LSC32V View Post
... 13.8 is very slow for your mods.
That's what I was thinking - 13.8 with a 100 shot of nitrous???
A Baumann shift kit or a J-mod is best for the tranny shift blues. If you increase the line pressure too much, the tranny won't be long on life. A properly 'tuned' tranny will outshift any manual shifting and be far more consistent.
Lay off the juice until you get the drivetrain where it should be.
Posted by: Staffamerica74
Get a fuel pump asap too cause you do not want to run lean... at all
Posted by: MediumD
At that point I would personally say screw nitrous, run C heads and a whipple 3.3 on the er.
Naruto Shippuden Episodes:Pay Day Loans:Loan:Debt Help:Themed Party
