Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Gen II Brake Light Help
Posted by: GMAN
Well, my neon light finally went out, and I didn't hesitate finding another one. When I purt the new neon brake light in, it only comes on when I press the brake. Did I miss something?
Posted by: unity
Ya, you missed the ballast. The neon rarely goes bad, its the ballast that goes. Did you replace the ballast?
Posted by: GMAN
Yes, I got another one.
Posted by: unity
So two ballasts and two lamps? Or just swap out one ballast? It would be odd to have two bad sets.
Posted by: GMAN
Unity you're not getting it. I replaced the ballast. It works. But....only when I press the brake. Not when i turn on the lights.
Posted by: Scorpio1118_2000
Try going back and checking all of you connections ,grounds ,solder points ,wiring ect.
Sometimes its the easy things that are a pain in the ass.
Posted by: GMAN
Common guys. I need some help. Why would the neon light come on when I press the brakes, but not when I turn on the light? What am I missing?
Posted by: 98LSC32V
from another site: "There should be 2 wires, one for parking lights and another for when you hit the brake, a third wire is for the ground. Make sure you got both hooked up correctly."
Posted by: GMAN
OK, I took some pictures from different angles. Everything is connectected. I just cannot get the light to come on. Only when I press the brake. I don't see what is not connected.
Posted by: regula44
where did you get the parts? Phone number or website.
Posted by: GMAN
I got a different ballast, this one works. Apparantly there are two mechanisms in the ballast. One for the brake light, and one to constantly stay on. Anyone heard of this?
Posted by: 98LSC32V
GMAN, was the first ballast a Glitch one?
Posted by: GMAN
Yes, the first ballast only lit up when I pressed the brake.
Posted by: 98LSC32V
Did you get another Glitch ballast or a used OEM one?
Posted by: GMAN
I think the first ballast just has a glitch in it.
Posted by: buddylee
the fuse box is almost the same as Town Car , IE at least 3-4 fuses that have to do with LCM ......
I had no break lites I checked the fuse that said "brake" it was cool.
then changed the switch at the peddle , still no brake lights .
I ended up sitting on the ground and pulling every fuse out, fourth to the last fuse I checked was burn out .
so check all 20 amp (yellow?) fuses
Posted by: GMAN
Buddy the ballast was just bad. I already put another one in and it works great.
Posted by: chickenviii
let me help, if im understanding correctly, gman bought a used OEM ballast, that had a glitch in it, and got another OEM ballast and it worked-right?
"glitch" is a member of .org that makes replacement ballasts (hence the confusion)
Posted by: GMAN
Ahhhh, I can see clearly now the rain has gone. Yes Chicken you are correct. My original ballast failed, I found another one, which had a "glitch" in it (Not to be confused with member "glitch) ). The second ballast didn't light up. It only lit up when the brake was pressed. I have been told that there are essentially to lighting sources in the ballast. one for the constant light, and one for the brake.
