Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Experiences with Winter tires?
Posted by: moneyUWM
Looking for ideas for solely winter tires...looked at a lot of threads but most are old.
Any great, new, winter tires around? Any experiences would be good to be told. Here in WI and in the city, dont want to get stuck in like 3 inches of snow.
Looking at the Blizzaks and WinterForce...looks like they have great treads but most reviews for them are FWD cars..
thanks, appreciate it.
Posted by: 02V8Sport
I ran Blizzaks on my stock 17's and they were GREAT! This year Im running Blizzaks again on my new 18" Jaguar S Type R wheels. I have them all ready to go to get mounted on the car once it gets cold in late November.
265/35/18 in back
245/40/18 in front
Posted by: macboy
There are two basic types of winter tires: Severe service winter or ice tires, and European or high-performance winter tires. The former is better on slick ice due to softer rubber, and the latter is better for highway driving. Ice tires will wear out faster and make more noise especially on the highway. They also do not handle as well because of tread flexing (feels a little 'loose' at high speeds).
All winter tires are only useful in winter until the tread is worn to about 6 mm or 7/32" to 8/32" (they usually start at 10 to 12 mm). The 'sipes' which are cut into the tread blocks and the soft rubber compound usually only go down that far, plus the tread becomes too shallow to displace snow effectively. After this point, many manufacturers recommend that you leave them on the car through the summer, and replace them the next fall. Or you can just replace them. Some fast-wearing ice tires like certain Blizzaks, are designed to be installed in the fall, used for 12 months, and replaced every fall. If you don't drive enough miles to wear them out in a year, then that scheme probably isn't worth it for you.
I use Michelin Pilot Alpin PA2, which are the European type, and I like them. I chose to use 215/55R17, which is the same diameter as the stock, but narrower, so they will float around on top the snow less. They wore less than 2 mm in the 5 months they were driven last winter (1/2 city 1/2 hwy), so I should get 3 or 4 winters out of them. Good thing too... they were not cheap.
Posted by: Frat-man-du
Blizzaks!
I have used them on my 98 Mark VIII, 2000 Stang and my 94 E-150. They are great! But as mentioned above they wear out fast and can be kinda noisy when they start to wear down.
