I plan on swapping to Cobra brakes, hub, lug pattern here soon so the hub bearings are going to be replaced shortly anyways. But if it's the ball joint, how would I troubleshoot them and replace them if necessary? |
Could also be bad end links. That's what was causing my problem, which was the same as yours. Luckily, that's a cheap and easy DIY fix.
Jelsoft Enterprises Limited.
