again...
1990's Siberian measuring stations close; global temp artifically inflated |
You just won't give up on that one huh? Despite the fact that I can find no credible documentation to back up your claim, let's assume it's true.
Do a google on "Siberia Warming". You will find thousands of articles on the evidence that Siberia is warming. Peat bogs are thawing. Roads and buildings are sinking into the ground that had formerly stood on solid ground for 50 years. Satellite images show that Siberian spring is arriving earlier than before. Even if you go back to the US-only figures, it clearly shows a trend upwards over the last 20 years or so. Notice where the vast majority of the positive numbers are. Like I said, use the Dow as an analogy. One or two isolated spikes or dips don't make a trend. A series of them do. |
*yawn*
Kaufman's just another Liberal liar. If he wanted to be truthful he would pay attention to what he writes. Instead, he delibrately mistates Limbaugh's view concerning GW. To this end, as you can see by Limbaugh's quote which Kaufman put in his article, Limbaugh does not disput GW in general, rather he disputes the so-called "consensus" concerning "man-made"/C02 GW.
Originally Posted by fossten
Whoops! NASA corrects its GW data; 1934 actually hottest year on record, not 1998!
| Contrary to some of the statements flying around the internet, there is no effect on the rankings of global temperature. Also our prior analysis had 1934 as the warmest year in the U.S. (see the 2001 paper above), and it continues to be the warmest year, both before and after the correction to post 2000 temperatures. However, as we note in that paper, the 1934 and 1998 temperature are practically the same, the difference being much smaller than the uncertainty. |
Well perhaps if you guys would stick to an argument there wouldn't be so much confusion. One day there is no GW at all, the next it IS happening but it's not the fault of humans. The next, well it might or might not be caused by humans, but warming is a GOOD thing after all. Make up your minds and you'd have a little more credibility.
We don't have to do that. The onus is on you GWers to prove your case. Your argument is threefold:
1. Global Warming is a reality. 2. Global Warming is caused by humans. 3. Global Warming is harmful. You must first prove the first before the second comes into play, and so on. It just happens that we are countering all points at the same time. 1. There is NOT sufficient evidence to PROVE that global warming is a certainty at this time. Even the temperature measuring stations are of dubious reliability. 2. There is NO proof that humans cause global warming. 3. Even if there were global warming, there is no solid proof that it would cause the global destruction which you fearmongerers gleefully promote. Here's an idea - why don't you religious zealots focus on one point and prove it, rather than running around scatterbrained, trying to throw out a bunch of disinformation? |
yourself (again)..........|
Global Warming is not a myth.
Keep on digging flip-flopper, I'm reloading.
Jelsoft Enterprises Limited.
