Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
2000 lincoln ls v8 popping in the intake help
Posted by: al a
2000 lincoln ls v8 popping in the intake.i just moved in the yard shut it off. 2 hours later i didnt want to start with out holding it to the floor.now its popping , skipping will not stay running.i changed the battery, plugs,maf, compression test one sided so far. fuel pressure NO CODES HELP
Posted by: BlntdEyez
sounds like you've got a problem. I don't own a LS so I have no idea. Sounds bad though.
Posted by: al a
i am hoping it not a bad valve
Posted by: lseguy
Quote:
Sounds like one or more bad coils to me. Common.
Posted by: al a
i am hoping it is the coils i did have oil in 3 hole.i check the coil swith a spark plug to see if there was spark and there was. i hate to go to the dealer.i had bad coil before and the code would read misfire cylinder 5 al
Posted by: al a
g
Posted by: 97stscaddy
How many miles on it? Did you notice any strange sounds when trying to start it?
Posted by: al a
yes it turned over real slow.it has 125,000 miles i did a compression test on all the cylinders two have 0 nothing and the other have 6 have 175 pounds i think they are 5 and 8 there on the driver side. al
