i dont understand your suggestion. spray carb cleaner around the intake manifold to see if the stumble gets worse. what are you suspecting that it is?
ok...lol, maybe i need to explain my issue alil better. the boucing of rpm's occur only when at a stop or just sitting in park w/ the ac off. now for the surging this typically happens at random, the jump in rpm's is very small, usually like 200 or 300 more. lets just say, i am driving doing 65 or 70 and my rpms are at 2200, it would surge around 2500.
the stall converter install was professionally done. and i was watching the whole time, so it was done right!
yeah, something tells me that the brake check valve is not the problem. i appreciate the insight, but hey, if all else fails i will give that a shot when i install my newly acquired big brake kit!
Hey, it's your bankroll. Me, I was glad it was only a 4 dollar part. Leaves me more money for other things.
Jelsoft Enterprises Limited.
