Originally Posted by 1wykdmk8
If you have a voltmeter you can take the terminal off of the battery, and place the voltmeter inline set on the current setting (Amps) and with the car off, there should be little to no draw on the battery. If there is simply start pulling fuses to see what is drawing the current.....hope that helps!
Jelsoft Enterprises Limited.
