Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
rear upper shockmount bushings
Posted by: wellby
When I did a coil spring conversion last year(1.5 drop) I also replaced the rear shocks and new factory upper mounts. This weekend trying to locate a thump in rear I found that the new shock mounts have fallen apart. I got of ebay the conversion shock mount, where can I find just the rubber bushings for the shock mounts. I know the come with new shocks but since my shocks are only 1 year old I would hate to by new shocks just for the mounts. I'm not looking for anything fancy, just plain old rubber but I will upgrade if that is my only choice. Thanks, Mark.
Posted by: whiplash15
Most auto parts stores have shock washer kits sepapately.
Posted by: mespock
You should have just used the rubber bushings from the new shock that you installed when you did the conversion...
All you do is clean out the old rubber and put in the new that come with the new shocks......
or at least that's what you should have done... I'm guessing they are available at parts stores... You could check www.rockauto.com also but it would cost as much as the bushings just for shipping...
Posted by: newguy
how about these http://supercoupeperformance.com/par...spx?partId=502
