They most often crack starting from the inside of the bottle itself. at 65k miles or so, mine had a ton of spiderlike, hairline cracks that ran vertically inside the bottle. 2 or 3 found their way from inside to outside of the bottle. Almost impossible to see when the bottle was cold. And the bottle wouldnt leak at all then the car/bottle was cold. But when the car got full hot, the expansion of the cracks would case the coolant to leak out of the backside of the bottle, near the brake booster. My telltale sign was coolant on my garage floor just behind my drivers side front tire.
I removed it, and epoxied it GOOD with hard epoxy. First drive, the leak began at the edge of the epoxy. Replaced with a new bottle, and that was that. Tip: You can get to that lower hose clamp easily if you remove the drivers side plastic wheel well liner. There is a hole in the chassis RIGHT where the clamp is. |
Mine had i think a total of 14 cracks in it. They were all over the thing.
Mine had cracks all down the backside. They were not visible till the bottle was removed.
Almost forgot..the dealer's replacement bottle comes with that lower skinny hose already attached. Someone here posted that it's easier to climb under the car, and actually remove the hose from the OTHER end..not the end where it attaches to the underside of the bottle.
So..in essence..it appears that the proper way for the repair is to loosen that hose clamp on the other end, remove the hose..then go back up and pull the bottle/hose assembly out of the car. |
The cracks will most likely be along the edges of the bottle. Mine had cracks and every single corner. I couldn't see any of them while it was installed, but when I had it out, it looked horrible. If you are wondering if it is leaking from the bottle, fill up the bottle to the full mark and run the car and let it sit for awhile... if it is leaking bad you should see some small drips behind the driver's wheel.
Jelsoft Enterprises Limited.
