I need an OEM LS Grille Emblem for my freshly painted McClaren grille. FLM does not sell these without purchase of the grille and I don't want to remove the one on my OEM grille....ARGH!!! Anybody have a busted up grille with a good emblem they can part with??? Can't believe this part cannot be acquire through Ford.
Thanks, John |
If you want an OEM emblem for your new McClaren grille, make sure you use an OEM emblem from a stock FRONT grille and NOT the rear license plate surround. The reason is that the curvature of those two emblems is different, so an OEM emblem off the rear surround won't fit properly on a front grille.
Jelsoft Enterprises Limited.
