| You asked if you need another jack.. From what I got, you were talking about two jacks per side. I was telling you that you only need one jack per side, leaving the car on the jack as you work. You obviously didn't understand the answer that I gave you. |
Would you not need one to jack up the car and then one to support the assembly. By this I mean one to hold up the area behind the wheel so that when you take the suspension appart it dont just fall to the ground. You take off the bolts and then lower the shocks/struts till they can be removed with out harming them and allowing them to fall.
I guess thats as close to a thumbs up as I can find, next to the one for the title.
I have one more question for those that have done this themselves...Do the springs need to be compressed to remove the shock/spring assembly, either front, or rear?, or will they come out so the springs can be compressed on a bench?
I have one more question for those that have done this themselves...Do the springs need to be compressed to remove the shock/spring assembly, either front, or rear?, or will they come out so the springs can be compressed on a bench?Thanks for anything you all can share....yes, I have searched high, and low, and this is the last question I have! ![]() |
If anyone wants them.. Here is a write up on how to change out the springs.
It's for my 2001, but it's for all 00-06 LS's.. It has three files. 1) taking off the front assembly 2) taking off the rear assembly 3) switching the springs Eibach.zip Download |
Jelsoft Enterprises Limited.
