can u get me a name of that n8? it would be great to order.. i havent been able to find it at discount or anything like that..
Sorry, you said you had a camera in the key hole.
I believe the rear seats fold down. Can`t remember if they release from inside car or trunk. My LS isn`t home right now, otherwise I would check for you. |
Go to Target and buy a Black and Decker charger.
It plugs into the cigarette lighter and gives you enough power to open the trunk from the button in the car. Then you can jump it. It costs $50. |
i didnt want to say anything about that one.. i just let it ride..
but it seems to me you could jump it from any point along the cables.
...I dont believe there is a trunk release lever inside the trunk.
From the factory, there is an emergency trunk release in the trunk. It should have a glow-in-the-dark T handle, unless someone removed it, and it should be hanging from the inside of the trunk lid. It is true that it's a cable-pull, not a lever, though, so someone may have clipped the cable, or it may have gotten stuck behind the interior trim.
I don't remember if it's Federally-mandated, but it's standard equipment on all cars with trunks, and has been for a decade or so. It's included as a safety feature, to prevent people from being trapped inside the trunk. (That's also why the handle is glow-in-the-dark.) |
Jelsoft Enterprises Limited.
