Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Taping noise?????
Posted by: JMIG118
Well it been 48 hours the problem seem to be getting wrost by the day,
before it would start when turn on the ac, and now it starts the when i start up the car. it sounds like a air vent flap that opens and closes, i need some good advise on this issue.
Posted by: TownCar
Well, that would be better described as a banging rather than a taping, no?
On your 97 TC that might be the Blend Door Actuator broken, allowing the door to flap around.
Typically that would also include undesirable airflow temperatures.
Posted by: JMIG118
thanks i will check that out, I have noticed it is come from inside the dashborad inside of the big black ac box behide the glove box. it now starts taping once the car is started. and will not go away it does slow down when i brake hard. i dont know what this tapping is it sound like a ticking bomb. and it is geting on my nerves.
Posted by: TownCar
How 'bout the temperature?
Does it flow AC cold when you ask it to, consistently?
Posted by: 95ltc
I WAS HAVING (STILL HAVE EVERY NOW AND THEN) THIS PROBLEM. DO THIS TEST:
http://www.lincolnsonline.com/tech/00128.html
OR GO TO MY OLD POST:
http://www.lincolnsonline.com/forum/...ad.php?t=50060
Posted by: JMIG118
What I just found out the the issue is, yesterday going home I turned on the heater and put the temp to 90 and it blow only outside air no heat. turn on the ac and it would blow cold. all this time while still tap, do you guy thing to the temp silanido.
Posted by: TownCar
So, does this mean you did not run the diagnosis procedure that 95ltc posted?
I'm guessing Blend Door Actuator however, we may never know without the test results
Posted by: JMIG118
Just did test... you'll right on... error 024 fault in blend door cali during self test.... so who know to to fix this issue????
Posted by: TownCar
It's not a fun job.. one part is better done with a buddy helping.
Basically it's like this;
Loosen steering column, so it can move down a bit
Loosen gauge cluster so it can move a bit out of the way
Disconnect all the dashboard fasteners
Get your buddy
Pull back the dashboard to gain access to the BDA (blend door actuator)
Curse allot while removing the Actuator
Reverse all that to have a car again
Our friends at LincolnsOnline have written this process up:
http://www.lincolnsonline.com/tech/00020.html 1997
http://www.lincolnsonline.com/tech/00175.html 90-94
Posted by: 95ltc
Get your buddy
Im going to have to replace mine pretty soon.
Posted by: TownCar
I'm still knockin' on wood
Posted by: JMIG118
THAT ALL....lol... I get to it maybe next week i have to get bda first. but it really doesnt seem that hard. thanks guy for the great help.
Credit Card Consolidation:Remortgages:Movie:Free Advertising:Loans
