Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Need help...
Posted by: Sal329
94 Mark VIII
Hood will not close. It latches but will not stay down.
The wipers work on High only.
Any suggestions?
Thanks
Posted by: JMiles_T
Are you sure you're pushing down hard enough?
I sometimes have to slam mine down pretty hard on my '93.
Don't know about those wipers though. Multi-function switch perhaps?
Posted by: Sal329
Hmmm I thought I did lol I guess I can try again.
Posted by: Moes8
Hood Hinge
Before adjusting the hood hinge (16796), make sure that the hood (16612) is properly aligned. The hood hinge can be moved side-to-side to align it with the opening in the hood inner panel and up and down to obtain a flush fit with the front fenders (16005).
Loosen the hood latch retaining bolts until they are just loose enough to move the hood hinge.
Move the hood hinge side-to-side to align it with the opening in the hood inner panel.
Loosen the locknuts on the two hood bumpers (16758) and lower the hood bumpers.
Move the hood hinge up or down as required to obtain a flush fit between the top of the hood and front fenders when an upward pressure is applied to the front of the hood. Tighten the hood latch retaining bolts to 10-14 Nm (89-124 lb-in).
Raise the two hood bumpers to eliminate any looseness at the front of the hood when closed. Secure the hood bumper locknuts.
Open and close hood several times to check operation.
If correct hood latch (16700) position is not obtainable, remove two locating pins from hood latch by tapping them into the radiator support (16138). (They will eventually fall from the vehicle.) Then follow Hood Alignment procedure.
If hood closing efforts and inside hood latch control handle and cable efforts are too high, adjust the hood hinge assembly upwards and/or the hood bumpers downwards.
Posted by: Sal329
Thank you, I will try tomorrow.
Posted by: kustomizingkid
That is a very informative post about hood alignment.
One thing that is always worth trying and should probably be done in conjunction with a complete realignment is to lubricate everything. The hood on my Crown Vic wouldn't open without someone hitting it while pulling the latch. I sprayed the hinges on the latch with a little lube and now it pops right open.
