i got my lincoln almost 3 years ago, and i always had this problem:
the car virbrates/shakes when changing speeds i am assuming. most of the time it happens between 38-43 mph but sometimes it happens at higher speeds. it always happens when changing speeds. i dont know if the transmisson is slipping or if something else is possibly wrong. someone please advise.
Posted by: kustomizingkid
Change the fluid with brand new Mercron V, if the problem continues reprt back for further analysis.
Posted by: unity
And dont forget to drain the torque convertor and FLUSH the trans cooler lines.
If you also have hard 1-2 shifts you may want to replace the 1-2 accumulator.
Posted by: JoeyLincolnMK8
there is a chance that this may not be a tranny issue. you could use a rotation/balance/alignment. or new tires. but if it is a bad shudder. most likely low fluid or you need a flush. remember to stay alive use mercon V
Posted by: mmtphoto
you are describing the exact problem I had with my departed 93 Mark-change out the trans fluid for Mercon V, do the torque converter drain while you are there and do the 1-2 accumulator, it will feel like new-not a hard job, just messy.
