I just never had to post anything because all the information i ever need was here... SO THANK YOU for always being here!
but anyhow after buying the car problems started to present them selfs...
at that point i really wanted to keep the air ride system but getting to pricey to maintain cause the roads around here suck! I went ahead and got the lowered strut and coils from American air (eddie, great look and feel by the way) through reading on here (again thanks!) that was about $450 something like that... and this time i did the conversion myself from instructions i got off of here. (which made it relatively easy) thought i was done with the suspension for a while but nope.. my shocks went out
replace shocks senso trac's and decided from reading on here to do a little preventive maintains and replace the upper shock mounts since i was already there about $150
thought i was done with suspension again but nope every time i would turn the car or go over bumps the car would creak... so i looked at the usual suspects and they were all kinda worn but some of the seals were totally gone on the drivers side ball joint so i replaced that.. Still heard creaking so picked another part that looked really worn and a lot of reading on here decided to replace the sway links.. and then the creaking was gone.. after doing this i was noticing that i lost a lot of vibrating in the stearing wheel was gone.. and was going to try to get more of the vibrating gone.. usually vibrated when i got on it or at high speeds.. so i replaced a engine mount on drivers side.. still have have vibrating but narrowed it down to passenger side ball joint and or engine mount
i couldn't concentrate on this problem now cause my transmission was acting up and i figured it was shimming a little and might as well get it fixed took it to a local shop to be rebuilt for 1,400 worked good for 14 months, 2 months after they would pay for it to be repaired then strated doing the same thing again
so recently took it to AAMCO against a lot people said on here to do but i wanted the lifetime warrenity and didn't want a local shop again... and had to pay for it!! $3,500.. and have had to take it back to them 4 times still not done right they have to order a replacement transmission for me
so now i am bout 9,000 into it and i also bought $600 hydroedge's tires... new rotors drilled and slotted and performance brakes from R1 concepts (from what i read on here
about $300 and put a python car alram $900 after install.. and 2 12" audiobahn with mtx amp and box $450... And ohh yeah 1 other thing i had stuttering when it was idle so i went to replace spark plugs and and found deteriorated rubber connecting coils and spark plugs covered in oil
so replaced all coil rubber things... replaced valve cover gaskets and spark plugs
that was about $200
also spilled some damp rid in back seat would like to replace ....ohh yeah 10 disc don't work i just us SIRIUS sucks not having CD player...
.... im only 2k behind you with an IDENTICAL car.... kinda scares me
) I suppose if your heart is set on another color or options than go for it but I wouldn't. You'll pick up a '98, searching for low miles, and have to do it all over again. Or, you search for one with more miles and hope that all of this has been taken care of. Too much of a risk if you ask me.
that and when i was pricing the seats in the car to replace.. the seats are different from the LSC and a nonLSC mark viii
so i was thinking take my car now get it fixed at Macco for like $1,000 and put the left over 1,500 back into the car and try to fix the rest of my problems... But still left with rebuilt title and will NEVER get the money i put into it
or maybe i was thinking if i could find a wrecked mark viii LSC for about 1,000 buy that... steal the parts i need (seats,electric pump,disc changer,telescoping stearing assy.) to get my mark vii back up to par and sell the wreaked mark viii . Is there anything i might be missing? somehow that just seems to easy?
You're missing a spell checker and some good sentence structure software..
out of mine all the time.
breaks or wears out, I fix, all is good. But I never seem to replace the same things twice. |
Ya know, I think you can only try to be funny for so long before you just look like an
$900 Python car alarm
I guess I am going to need seats (all 3 LSC style), steering column, (just saw on ebay for like $250) and that electrical pump for the secondary injection. (p0411 or something like that)
Jelsoft Enterprises Limited.
