Gee Frogman, what a helpful response that was. We're all so glad you took time out of your busy day to post that.
Anyway for E85 you will need a tune. This isn't a kind of tune you can mail order either, you'll need somebody with experience and a wideband at minimum. E85 eats rubber, so eventually anything in your fuel system made of rubber will disintegrate and need replacement with alternative materials. You may see a reduction in fuel economy of around 25% on E85 compared to gasoline because of the lower energy content of ethanol. You may end up running your injectors at a high (80% or more) duty cycle, which means you may end up requiring higher flowing injectors. You should see a slight (>5%) increase in power on E85 over premium gasoline with a good tune because it'll allow more timing. |
Jelsoft Enterprises Limited.
