Hi everyone, my interior lights won't work. I tested the fuses but, they are all good. The dash lights and the trunk lights work. Am I missing something or is there another fusable link that I should check? Thanks, Max
Posted by: Frogman
Well, didja open the door?
Does the LS have a Lighting Module like those "old" Mark VIII's do?
Are there fuses in the engine compartment as well as in the cabin? Did you check them all?
Did you try opening other doors, to see if maybe the door you're using has a
bad switch?
Posted by: fuzzyb
What all have you checked?
Door open?
Remotely unlocking doors (do the puddle lamps turn on)?
Interior Light Switch (on dash)?
Can you separately turn on the overhead console spot lights / rear passenger lights?
Posted by: maxlsv8
Door open------- no lights
Remotely unlocking doors (do the puddle lamps turn on)?------ Nothing
Interior Light Switch (on dash)?-------- I tried but still no lights
Can you separately turn on the overhead console spot lights / rear passenger lights? --------- No I can't
Posted by: DarkMansLSEV8
Fuse!
Posted by: fuzzyb
If you have checked all the fuses then it's probably a fuseable link. Unless someone else knows where it is,
take it to the dealership and kiss your tax return bye bye.
Did you check fuse #5? I haven't verified this is the fuse with my car but looks right in the manual.
