Originally Posted by fuzzyb
It is hit or miss trying to see coolant on the dip stick. Another way is to change your oil and put your used oil in clear plastic jugs. Let them sit there for a day or so (don't move). If there is water in the oil it will separate from the oil settling on the bottom.
Originally Posted by NateRW21
Not to sharp shoot you... But I'm pretty sure the oil will end up on the top, coolent on the bottom. Oil is less dense
Jelsoft Enterprises Limited.
