Originally Posted by owlman
The battery is generally a "consumable" item like tires and wipers and not covered. But you might as well call around and ask.
Originally Posted by my04lincoln
Quote:
Ryan |
Originally Posted by Archer28
Thanks for the replies all, my04 was right, my local dealer is supposed to replace the batery free of charge today.
I charged the old battery up this morning and it started fine, didn't sound weak at all. As my wife was driving to the dealership to have the battery replaced, she said that every time she stopped at a light or sign, the console would display "apply park brake". She also got a "check park brake" or "service park break" (can't remember which) on the way.... I don't know if that would be battery related? |
Not so! If it still has the factory warranty then it will be covered.
Ryan |
UPDATE
Just spoke to the wifey and after taking the car in, they ran a diagnostics, and the battery checked as good. They said they couldn't replace it unless it failed the test. They did reset something that fixed the brake messages. She hasn't had any issues on the way home. I still can't for the life of me figure out what caused the battery to drain down. I thought the LS had a safeguard to prevent the battery from draining past its ability to start the car. |
Originally Posted by GWL
Mine did the exact same thing and I got the same results when the battery checked OK. After the forth time it happened, the dealer replaced the battery despite it reading Good. Knocking on wood, but no problem since for about 1 month now. The problem was so intermittent, that I cannot be sure that it has been solved. My dealer even kept the car over night to try & check for an unknown draw without success.
Originally Posted by beaups
lol it's gonna be the battery. when the voltage drops too low you get the "service park brake" message and a code....
Jelsoft Enterprises Limited.
