,AS I ACCELERATED OR EVEN AT STARTING IT..OK THE BELT IM THNKING
...THE BELT NOT EVEN 1 YR OLD..THINKIN OK WHATS GOIN ON HERE,OK SO I LOL PISS SOME WD40,OR BELT DRESSING...THINKING OK IT'S GONNA QUIET DOWN,IT DID FOR ALIL BUT IT KEPT COMIN BACK..NOW IM GETTING FUSTRATED
,CAUSE IM SEEING IM SPRAYIN EVERY TIME WHICH ISNT GOOD.....TURNED OUT TO BE THE BERRING ON THE LOWER BLACK PULLY TORDS THE LEFT WAS THE ISSUE,AND ALSO SEEING LIL LIL LIL TINY PEICES OF MY BELT COMIN OFF THE EDGES,AND THE SURFACE OF THE BELT WAS GETTING ALIL SHINEY TOO,AND THAT PULLY WAS GETTING ABIT BEAT UP AS WELL AFTER TAKING OFF THE BELT,LIL BUMPY $HITS ON THE SURFACE OF THE PULLY...
Originally Posted by MediumD
First of all if you piss some WD40 you've got serious medical issues. Second do not put WD40 or any lubricant on a belt. The belt turns important parts, and requires friction to turn those parts, and a lubricant is designed to reduce friction. Belt dressing (not a lubricant) is designed to clean your belt off, which increases the friction between the belt and the pullies which is what you want.
Finally, TURN OFF YOUR CAPSLOCK FOR THE SAKE OF ALL THAT IS HOLY. |
..lol- and no i dont have medical issues-btw-im as heathy as they come
just to clear this up i didnt actually spray the stuff on the belt,it was tords the back of the pully from where the noise was comin from...and yes the car was off when i did that. anyways....she'a all better
Originally Posted by poniesviii
I don't know man, that belt dressing leaves everything it touches 'grippy' such as your skin, as in .. adding something to your skin other than just cleaning it. Leaves a sticky mess everywhere. But, It's not intended for anything other than V belts! Strictly not for serpentine, only quiets for a few seconds then makes the sound worse is all. So .. lol .. not for our cars at all.
WELL MY BABY RECENTLY STARTED SQUEELING LIKE A PIG
,AS I ACCELERATED OR EVEN AT STARTING IT..OK THE BELT IM THNKING ...THE BELT NOT EVEN 1 YR OLD..THINKIN OK WHATS GOIN ON HERE,OK SO I LOL PISS SOME WD40,OR BELT DRESSING...THINKING OK IT'S GONNA QUIET DOWN,IT DID FOR ALIL BUT IT KEPT COMIN BACK..NOW IM GETTING FUSTRATED ,CAUSE IM SEEING IM SPRAYIN EVERY TIME WHICH ISNT GOOD.....TURNED OUT TO BE THE BERRING ON THE LOWER BLACK PULLY TORDS THE LEFT WAS THE ISSUE,AND ALSO SEEING LIL LIL LIL TINY PEICES OF MY BELT COMIN OFF THE EDGES,AND THE SURFACE OF THE BELT WAS GETTING ALIL SHINEY TOO,AND THAT PULLY WAS GETTING ABIT BEAT UP AS WELL AFTER TAKING OFF THE BELT,LIL BUMPY $HITS ON THE SURFACE OF THE PULLY...WELL I GOT HER FIXED AND SHE'S QUIET LIKE A MOUSE! JUST THE WAY I LIKE HER! THIS WAS MY EXPERIANCE WITH MY BABY SQUEELIN LIKE A PIG! ![]() |
WELL...RECENTLY STARTED SQUEELING LIKE A PIG
True.
Originally Posted by pepperman
Guys if you haven't noticed by now the GODDESS is going to keep doing CAPS no matter what.
Jelsoft Enterprises Limited.
