Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Need wheel alignment specs
Posted by: Limey
I need to have the front wheel alignment checked on my '92 LSC.
Does anyone know what it should be set to? I assume it will be toe-in, but by how much?
Posted by: Limey
Please?
Posted by: torquemonkey
I will post that info later. I'm not near my books at the moment. Should someone beat me to the info, thats cool.
Posted by: Limey
bump
Front Wheel Alignment (curb height with 1/2 tank of fuel)
Item...............Nominal..............Minimum... ...........Maximum
Caster: (1)(2) +1.5 deg.............+.60 deg..............+2.7 deg.
Camber: (1).. +0.00 deg...........- 3/4 deg..............+3/4 deg.
.....................+0.125....................0". .................+0.250"
Toe:...............+ 1/8"......................0"..................+1/4"
.....................+3.2mm.................0mm... ..............+6.4mm
Clear vision: (3)-0.9 deg................-3.9 deg............-2.1 deg.
(1) Maixmum side-to-side difference between wheels (left to right) to be within -.9 + .9 with caster and camber set to specification.
(2) Caster is factory set and cannot be adjusted
(3) Steering wheel angle - negative is ccw.
Taken from 1992 Lincoln Mark VII Service Manual: 04-00-7
Posted by: OldSchool1
Nice information.
I have yet to look for it in my manuals.
Thanks.
My pleasure.
Posted by: Limey
Thanks very much.
I'm gonna sound stupid now, but am I right in thinking the 1/8th inch is toe in? Generally only front wheel drive c**p is toe out.
Posted by: Limey
bump
Posted by: Limey
Posted by: chickenviii
its toe in, if it was toe out it would be, -1/8"
Thanks Chicken, you RULE!!!
ask and you shall recieve
Posted by: Limey
Excellent. Thank you very much.
Now I can find out why one tyre is wearing on the outer edge...
Posted by: Dereck
Hi Limey
I get the same trouble with my Town Car (in fact all my Town Cars), it's the left front that wears on the outside edge I have put it down to our road camber and roundabouts as I have had the frame and wheel alignment checked with laser alignment equipement.
Regards
Dereck
Posted by: Limey
Quote:
Originally Posted by Dereck
Hi Limey
Regards
Dereck
Guess what? It's the outside edge of my left hand front tyre too!
interesting theory, especially about roundabouts. Not sure why Lincolns would do it when UK cars don't though?
It might be worth going to the lower end of the toe-in range to compensate i.e. 0"-1/16th" rather than 1/4"
Think i'll turn the tyre around for now
Posted by: ND4SPDLSC
You could run a little bit more negative camber. If you're driving hard, the wear might improve or stay the same.
Posted by: Dereck
Hi Limey
It's not just Lincolns my friends Cadillac does it too.
I have tried varying the wheel alignment to compensate and have ended up with a slight drift to the left when going straight, funny thing is I have no problem when driving on the continent
Regards
Dereck
Posted by: Limey
Well, I'll update my findings here after I get it checked.
Debt:Mortgage:Remortgages:Debt Consolidation:Debt
