Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
I'm Confused
Posted by: 87lsc
Maybe you guys can shine some light on a problem that I'm having with my 88MARK VII... If I tilt the steering with up and then down, if the headlights are on the HEADLAMP OUT light blinks and the wiper come on. If I just turn on the parking lights that light blinks and the wipers again come on. If all of this is not going on the headlamps will NOT come on all other lights do BUT NO HEADLAMPS..... If you guys can help me through this problem then the MARK can go out at night.........
Posted by: ralph
I'd say it sounds like a bad ground, or even your munti-function switch is on its way to the crapper.
Posted by: 94m5
Check the wiring going through the steering column. Replace the multifunctions swtich also.
mike
Posted by: OldSchool1
Quote:
What a play on words
If you haven't corrected this problem yet, it'll probably be the (blue) multifunction switch AND your (gray and beidge) ignition switch show here:
http://www.thelincolnmarkviiclub.org...tionSwitch.pdf
Unsecured Loans:Myspace Backgrounds:Web Advertising:Credit Cards:Credit Cards
