Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Heated Seats
Posted by: luvmyls
Ok, I am gonna ask a dumb question. IF I find out now after 2 years that I have heated seats I will fill like a big dummy . But the other day I thought someone said on this sight that there is a button on the air conditioner panel for heated seats????
My question is....IF I have electric seats where is the switch??? I love the leather but it is a B*tch in the cold weather!!!
Posted by: luvmyls
By the way I have a 2000 Lincoln LS V8 as far as i know it has everything except to my knowledge heated seats?????
Posted by: LincolnTech38
heated seat buttons are next to the ashtray on either side in the wood grain
hard to miss.
the button on the EATC control is for a headted WINDSHIELD and it is the button to the left of the rear defrost button. (if equiped)
Jay
Posted by: luvmyls
Then that would answer my question I don't have them! because i've never seen that switch
Posted by: teh_milz
Quote:
hard to miss.
Jay
oh that is a nice feature! i love it during these winter months
Posted by: luvmyls
You just got to rub it in don't you????? Just kidding!
I know leather seats are not sweet in the winter time or hot summer for that matter!!!
Posted by: teh_milz
i dont have heated seats, just heated windshield, oh and you could buy a remote start system and just have your car all warm and toasty when you get in
Posted by: jmz2k5
wat have you guys heard about adding remote start (easy/DIY?). I've seen some online for under 100 bucks and was wondering if anyone's installed themselves.
And I love my heated seats!!!
Posted by: eastcoastLS
2000 ls didnt come with heated seats.
if im wrong correct me
Posted by: 02V8Sport
I install remote starts on the side almost every weekend now since its getting cold. The LS install isnt too bad, you have to remove the lower panel under the steering wheel and work upside down using crimp slicers to get to the wires behind the key cylinder. I have installed remote starts on 6 LS's ranging from 00-06, all are the same.
I recommend remote starts by asianwolf on Ebay, you can get them for $50 + the ignition bypass module which is about $20.
I wouldnt say it the easiest job, but I have never been afraid to tear anything apart on a car before.
Posted by: ToddG
It was available as an option in 2000.
Posted by: ToddG
Quote:
The LS was NEVER available with a heated windshield. There is a heated wiper park that is standard on all LS models, but no heated windshield, even as an option.
Posted by: lseguy
Does installing the remote start disable the built in PATS anti theft system?
But I personally wouldnt want one even if it didnt. An engine under load warms much quicker than an idling engine. An idling engine also puts out more pollution and burns more fuel. It also could be a problem if an oil or coolant warning light comes on, and you are in the house/not able to attend to the warning light.
[quote=lseguy]Does installing the remote start disable the built in PATS anti theft system?QUOTE]
Yes but only when the remote starter send power to the bypass unit to disable the PATS. Otherwise its enabled at all times except when the remote start disables it.
Posted by: northstar11
My 2000 Ls8 has em. Or did. the driver side quit workin now. standard problem from what I hear.
Posted by: lseguy
[quote=02V8Sport]
Cool. Thanks for the clarification.
Posted by: MangoMan
Where is the button for the heated winsheild?
Posted by: SoonerLS
It heats the wiper park area, not the whole windshield, per page 39 of the manual ( http://www.lincolnvscadillac.com/tec...nersManual.pdf ).
Quote:
Electric window heaters
(heated wiper rest) — Located at the base of the windshield, this
feature heats the front glass area below the area heated by the front
defroster where the windshield wipers sit in their parked position. When
activated, the feature keeps the wiper blades warm and reduces the
chance of ice build up on the blades. The indicator will light when the
feature is in operation.
With the ignition in RUN and the engine running, the feature will be
automatically enabled if the temperature is below 5°C (40°F). The
feature can be manually selected or deselected at any time. However, the
automatic feature will be enabled each time the engine is started.
In cold, dry conditions where wet snow or ice is not present it is
acceptable to manually deselect the operation of this feature.
The feature will run continuously unless a low battery condition is
detected, or unless the feature is manually deselected, and will only
activate when the vehicle engine is running (to prevent excessive drain
of the vehicle battery).
Posted by: DLS8K
you are wrong
Posted by: PaulJK
If you wanna add heating to your seats, here's a kit for you:
http://store.summitracing.com/partde...autovie w=sku
Posted by: bill5
My 2000 has heated seats.
Posted by: ToddG
Quote:
My understanding is that there is no manual switch for activating or deactivating the heated wiper park. It is totally automatic.
Posted by: SoonerLS
Quote:
I know it's sort of automatic on the 2nd Gen LS (at least on the '04 and '06, it comes on automatically at a certain temp, but it also comes on with the rear defroster, just like the heated mirrors); however, the Owner's Guide indicates a control on the 1st Gen (at least in the '01 manual I referenced above).
Of course, the Owner's Guide for my '04 didn't reference the moisture-sensing wipers that my car definitely had, so it's possible that the Guide is wrong...
Posted by: jolinc01
My 01 has a heated wiper park button beside the defrost button. I can turn it on or off at any time. However is does automatically come on at 40 degrees or colder.
Posted by: ToddG
Quote:
Very cool, I stand corrected. Can you please post a picture? I'd really like to see what this looks like.
Posted by: jolinc01
I took a pic but I can't figure out how to attach it to my post.....
Posted by: ToddG
In the reply box, under "Additional Options" click on the "Upload Photo" button. Browse until you find the path to the picture, and click upload.
Posted by: jolinc01
here is a pic of the window park heater it's the 2nd button from the right. I couldn't get the white images on the button to show up that well.
Posted by: ToddG
Well I'll be. Dang if I didn't learn something new today about the LS. Thanks Jolinc01!
Posted by: Fla02LS
I dont have too much experience with freezing weather, although Florida did have some minor snow flurries last night, but what function does that "heater" do and how hot does it get. I am assuming its so your wiper doesnt get stuck to the windshield, but does it really work?
Posted by: ToddG
Quote:
The heated wiper park gets warm enough to melt snow. I know, because thats what happened in my 2003 LS (have not experienced snow in the 06 LS yet). If you put your hand on the element, you can notice a definite warmth. The best part is that it melts ice particles that would otherwise stick to the windshield wiper blades and result in streaky wipes. Melting that ice from the blades helps keep the windshield cleaner as the wipers wipe.
Posted by: macboy
Here's another tidbit of information. On the 00-02 LS the heated wiper rests come on automatically a just above freezing temperatures. Both outside mirrors are also heated, and come on with the wiper heaters. You can control them manually with the button as in jolinc01's picture (p.s. try using macro mode next time). Near freezing you will see the light on that button come on automatically. Rear window defrost is separate and is manually controlled.
On the 03-06 LS, the heated wiper rests still come on automatically near or below freezing but you have no manual control. There is no button, and no light to indicate they are on either. The heated mirrors do not come on automatically; instead they come on with the the rear window defrost, which is manually controlled. Maybe they had no space for the buttons after moving the heated/cooled seat buttons here.
