Originally Posted by Redwingvksm
When cranking - did you crack the throttle? It may be a bad coolant/air temp sensor.
Does it putter and SOUND like it's gonna start - until you let go of the starter? |
Originally Posted by MediumD
It does fire while it's cranking until I let go of the starter. Throttle position makes no difference. I sprayed some starting fluid, no difference.
Jelsoft Enterprises Limited.
