Originally Posted by blkZ28Conv
I have read it is a waste to use higher octane fuel when vehicle does not need it and that actually may create problems from incomplete combustion.
What are your thoughts. TIA |
Originally Posted by BigT
Over ten years ago my wife had a Tarus that I told her to put the middle grade gas in instead of the cheap regular. After a couple of tanks the car starting running rough, hesitating and hard to start. I took to the local Ford dealer that a friend of mine was the service manager and I told him the problems we were having. The first thing he asked me was what gas was I using and I told him we were using the mid grade. He said the cars computer was programmed for regular and would not run right on higher grades of gas and cause the problems we were having. I switched to regular gas and after one tank all the problems went away and didn't come back.
This is the scenerio that I hear from my mechanics. Because of electronics in todays vehicles the recommended octane is the one to use. I also see the point of mixing a higher octane fuel periodically just to get peace-of-mind that the min is covered.
I guess I should follow the manufacturer's recommendation with the same conviction that I do with my higher octane requiring vehicles. Z28 and LS400 require premium by Manufacturer Escalade needs min 87 by Cadillac recommendation. Thanks everyone for your insights. Addendum: The octane rating has nothing to do directly with the power produces by an engine. Octane is a pre-ignition (knock) inhibitor not a power additive. If all ignition perimeters remain at their maximum (not activating anti-knock timing retardation) both fuels will produce the same power. |
Touche'
That is correct. That is why people desire certain brands of gasoline (i.e. Mobil vs Citco) and actually feel a seat-of-the-pants differences. This is related to the refining process but very little to do with octane rating or anti-knock activity. Small poll: What octane rating to you run in your vehicle? What is the recommended requirement? (Let's take cost difference out of the equation but focus on engine care and performance). 2000 Escalade: I use 87 (fulled with 93 last time). So far no discernible difference. I will check mileage. |
Hi Kevin,
I am again a little confused. From your tests even a small change lead to a significant reduction in HP (10%) and a change for the worst for MPG. Why would GM recommend the usage of lower octane fuel with these perimeter changes and the potential of carbon deposits and its subsequent problems? I want to run the best fuel for my vehicle, the 3-4 dollar difference on a full tank is not a deal buster. TIA |
Jelsoft Enterprises Limited.
