Originally Posted by NYC LSC
That traction assist is really Anti-Lock Brakes. That's what you're seeing in that description.
Agreed both would probably use ABS sensors, but the control circuit would differ somewhat.| As far as information, check out http://thelincolnmarkviiclub.org |
Originally Posted by ocs
(What the heck then they meant by "SNOW-TRACTION ASSIST ... PREVENT ... REAR WHEELS FROM SPINNING"? Well, seems they did not really know themselves )... |
Originally Posted by OldSchool1
This sounds like an advertisement for a mid to late 90's car and NOT a Lincoln Mark VII...
| I hope that you decide to get the car. When the snow goes away, you'll have the best American Made luxury coupe built in the 80's! |
By the way... sifting through the information at thelincolnmarkviiclub, I've found there was a -- presumably -- limited slip differential for LSC at 1989, one "Traction-Lok Differential". Am I right, is is a limited-slip?
How does it work?
Any experience about how does it handle snow?
I'm told by the dealer the option is there on the vehicle (and I hope he does know what he is speaking of
In December, I sat one teenager on the front of the car and one on the rear of the car. Both ends lowered to the ground. Twenty seconds later, the air ride suspension returned all four corners to their trim (regular) ride height. I turned off the air ride suspension with the flick of a switch in the trunk and then I set the teenagers free. The car then rode about four inches HIGHER for the duration of the winter.
), everything works -- or so the dealer says --, Carfax said the VIN's clean, service book. The cons are: dealer pretty far in another state, aforementioned problems with registration, 120K miles.
Anyway, if you see any arguments why I should select this or that, I'd appreciate them ![]() |
I think you should get both.
You can never have too many Lincolns. |
Jelsoft Enterprises Limited.
