Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
98 Mark 8 AC problems
Posted by: wnapstead
My 98 Mark 8 LSC has 90,000 miles. The AC was working fine when I bought it. I don't drive it much but sometimes the blower won't work, then the blower works but I can only get heat out of it, after its been working for a few minutes. I would appreciate any ideas from anyone.
Wnapstead
Posted by: MonsterMark
I believe those are symptoms of the dreaded 'blend door problem.
http://www.lincolnvscadillac.com/sho...ighlight=blend
Posted by: Frat-man-du
Blend door is not a fun fix, but cheap if you do it yourself.
Sounds reasonable but what about the blower that works sometimes and sometimes not.
Usually a loose wire behind the glove box to the motor. I think there is a write up on that also.
I guess you have to remove the glove box to get to it. Is that a big ordeal or something simple? Once in there how do you identify the culprit, connection to the motor. I'm no rocket scientist when it comes to these things.
Thanks!
Quote:
Intermittent blower motor repair
I did the blower motor repair thing, it doesn't seem to be that. I've checked all the fuses. A guy on ebay selling main control units for these(dash unit), says it's common for these to fail. He's got a used one for $137. This sure seems like a crap shoot to me. The last several times I've run it, the blower doesn't run. It almost seems to have given up completely. What would you suggest I try next?
Incidentally, when I dropped the glove box door, It didn't look like the picture in the tech article. Must be from an earlier unit.
Thanks again guys!
Posted by: Brozly
You could try a little "cleaner" on the contacts, (WD40 should work) you clould check them with an Ohm meter at the conector as well...
Seems like anybody selling anything on Ebay has a common faliure item
Loans:Car Insurance:McDonalds:Free Ringtones:TwoGether - Dating, Romance and Love
