Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Nitrous and timing advanced
Posted by: 98LSC32V
I want to spray a small shot on my 98 LSC (50 shot), right now I have the SCT chip advancing the timing 4 degrees, will I be OK with spraying a 50 shot with the timing advanced?
Posted by: driller
I've been told you can go up to a 75 HP shot without any retarding in timing?
Posted by: 97quadcam
Just run a smaller gap in your plugs. If you go bigger then I'd back the timing off a little. But with a 50 shot you should be fine.
First sound of pinging....the back out of it and fix the problem. Or if you're scared then run some race gas in it when you take it out to race. But if you plan to do that then you should step it up to at least a 75 shot.
Homeowner Loans:Novela historica:Debt:Myspace Layouts:Debt Consolidation
