Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
door / handle key pad light
Posted by: aggiestckl
the light that lights up my keypad on the door is out.. anyone know what fuse to check.. or how to replace that bulb? is this common? its a 97
Posted by: LORENZOCHICAGOLSC
Ditto!
Posted by: 4.6powa
me 3. but... every once and a while mine will light up. and i noticed last night it lit up, but it was very dim.
Posted by: MrDoug
The keypad is a sealed unit, so your best bet is to replace it. Once you get the door panel off, its held in with an 11mm nut, so make sure you have an 11mm socket before proceeding. 93-98 Use the same keypad if I am not mistaken.
Posted by: marked8
I've seen them for as low as $2 on Ebay.
Posted by: 94m5
yes, they are cheap.
The bulb can be replaced tho. 194 is the number.
