Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Quick question about installing the 255 walbro
Posted by: Staffamerica74
I have the tank out and the old fuel pump out of the sending unit. This new pump is slightly different then the old one the filter is a bit of a different design and it doesnt want to slip into the retainer(the bottom where its got the two metal prong like things) that strattles the pump bottom of the pump. I just want to know if you guys modified the metal part that holds the pump in and if you changed the fuel hose that goes on the pump.
Thanks in advance
Posted by: torquemonkey
Gen I fuel pump replacement; http://www.lincolnvscadillac.com/sho...ight=fuel+pump
Gen II Fuel pump replacement;
http://www.lincolnvscadillac.com/tec...pump/index.htm
I don't know which year you have, hope this helps.
