Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
96 Continental will not start
Posted by: hotrodlincoln6
I have a 96 continental that will not turn over using the ignition key. I can jump the starter and it will start and run just fine. I tried resetting the anti theft system,but this did not help. Any Ideas????/
Posted by: Jibit
what do you mean by jump the starter? If I had to guess I would say you are just getting a clicking sound when you try to turn the ignition over? Unless the ignition is bad I would bet that your problem would be the starter solenoid/relay. I'm not sure about the continental but I would bet its mounted on the fender wall less than a foot from the battery
The starter solenoid is on the starter on the front left side of the engine. When I turn the key the car makes no noise at all. the black plastic piece around the ignition switch turns freely with or without the key in the switch. Is this normal?
Posted by: Jibit
Quote:
nope, that's not normal, I'm actually surprised you can get the key in, normally the black ring needs to be alligned properly to get the key in. I know a lot of my older fords had that problem.
Do I need to replace the ignition switch or just the piece that is turning? Also the anti theft light flashes even after I disarm the alarm system.
Posted by: Jibit
well that might be your problem then, the anti theft is cutting off the system not allowing it to turn over, I don't know enough about that year conti though
Does any one know what I shoulod try next?
